While testing engraved text vs outline text for an upcoming project, engraved text comes out slightly slanted. x and y axis are zero, speed 150. The picture attached shows the bottom line Reagan 10 is and outline of the text and the Reagan 10 above is engraved. The “A” and “N” on the upper line
Don’t let all the text mislead you. It comes down to this:
In Edit > Machine Settings, look in the X & Y axis motor settings section at the bottom, and look for the value of ‘PWM Rising Edge Valid’ on the X axis. Change that - if’s it’s checked, un-check it, or vice versa. Then, copy the new setting over to the Y axis as well.
Also, suggest you take a backup of your settings before making any. I think LightBurn actually auto-saves these but good to have an explicit backup.
