Is it possible to slice an object in half and keep both halves.??
Yes, you can use the ‘Cut Shapes’ tool for this. Draw a shape to be used as the cutter, like a box, then select everything you want cut, then the box, then click Tools > Cut Shapes.
Note that it doesn’t work for images yet.
