Slight bug found whilst importing an SVG file
Hi everyone, I believ i found a small bug in the newest update. Not sure where to post it so apologies if i am in the wrong place/category.
When i import an SVG (created in Illustrator) it seems to miss or move some anchor points. Attached is a screenshot of a snowflake (xmas season is coming peeps!) on the right is the imported svg and as you can see in the circled area it has distorted the design. On the left is how it looks when i just copy and paste it straight from Illustrator (and is the way it is supposed to look)
Has anyone else had this happen? Is there a setting that has changed, or is it an actual bug?
Hello Johan
Could you please email us as well to support@lightburnsoftware.com, adding the SVG in use as well as the Lightburn version?
Thanks
Sure thing. Thank you for taking your time to reply
From what I can see on your SVG, even when opened on a browser or back in Illustrator, the shapes are already incorrect.
From what I can see Lightburn is Importing it correctly.
So something in the export is not working correct.
Hmm, so an Illustrator bug then? here is a screen shot of the project open in illustrator
here is the problem it seems! Reverting back to my previous illustrator version now to see if it solves the problem
