I haven’t fiddled with this in a while, but I think it uses whatever speed is set at the console for a frame initiated from the console.
Frame from Lightburn is set in the move window, I believe.
I think it’s for the speed to move between objects when the laser is not firing while in ‘run’ mode. So if you slow it down it will effect the job time.
The PC sits on the left-side shelf with the monitor on top and a trackball out in front. I’m tweaking a 40% keyboard to replace that stock 103 monster.
It’s not much further away than the console and the display is much better!
