I’ve got two issues that have seemed to have started as of late. xTool D1 10W laser.
First issue:
- When I try to burn via the usb/serial connection the laser head is very slow and jittery, and will sometimes stop all together. No matter what movement speed. I have changed cables as well and no change.
-If I burn via that method in xTool Creative space, it will burn with no issue.
I typically burn via the SD card or wifi and those burn great.
I used to burn via usb/serial all the time with no issue
Second Issue:
- If i try to burn via the USB method above, I now always have to change the “mm/in” button back over to mm before I hit start. If I try to burn it while inches is selected, it will act as if it is reading mm and not convert to inches.
I have done several updates of the software as of late, so I am not entirely clear when exactly it started. Current version is 1.4.04
I removed Lightburn from my computer and reinstalled and the issues were gone for about a day, then they returned. Firmware is also up to date.
Is anyone else experiencing these issues?
