when you make 2 squares inside the other and set the power of the outer square in the property to 20% and don,t change it from the smaler one. The part right from the small square will will be burned with the default value of the layer an not with 20%
That’s not quite a bug - it’s how LightBurn does rasterizing. For the middle shape, you must also set the shape property power to the same as the outer one. LightBurn reads the power value from the last edge that it crosses, so the middle shape with power set to default is the last edge it sees when filling that second part.
