I’ve upgraded a K40 with Smoothieware and an SKR 1.4 + Wifi with ESP3D firmware ( https://github.com/luc-github/ESP3D ). ESP3D, additionnally to regular web UI on port 80, implement a TCP bridge to serial on port 8888 .
It’s easily testable using putty, opening a raw connection on ESP3D IP:8888 and seems to works.
@LightBurn When creating a machine template, i got only choice for “USB/Serial”. I’d love to have also an ethernet input in that box, allowing to choose ip adress & port…
That will allow to use K40 without cable…
Since esp3D works also with Repetier, Marlin & GRBL (a gcode Flavour to choose during setup), this could be a great improvement for adding wireles connection to GcodeLightburn version.
The idea was to install that driver, set it up as a gateway to the hardware ESP3D extension done to Smoothieware, allowing to use Lightburn/Smothie wirelessly.
Workflow is as folowing:
Windows 10 > Virtual com3 port connected to 192.168.20.23:8888 > WIFI NETWORK > ESP3D (ESP8266) > Serial0 > Smoothieware > K40 Laser.
I had some success with GRBL driver (see screenshot on https://www.civade.com/images/k40/grblsucess.png ). Grbl driver is able to connect and init homing in the machine. Moves are ok. I did not go further because my machine is smoothieware powered, and got a limited compatibility with GRBL.
However, when i’m choosing Smoothieware driver, port opening does not seems to go well (see https://www.civade.com/images/k40/smoothiefailed.png ). Ethernet counters are increasing,but opening failed and Lihgtburn stays in “waiting for connection” state.
Nothing changed on the hardware between those two tests. It’s always the same K40/Smoothie/ESP32 Machine… The only difference is the software driver used in Lightburn.
I can’t go further in diagnostics, since i dont know if code for opening port in Smoothie and Grbl driver is the same. I suspect not, since the activity monitor shows traces on opening parity even, 7 bits, and unknown hangshake. Both traces can be seen in both screen capture.
