Does LB have the ability to snap, or mate objects? For instance, I have to rectangles that I want to be a the same height. Can I select them and is there a command that would do that? Or if I want the sides of two object to be flush against each other. Is there a command for that?
Snapping
When you move the mouse over a shape to select it, you will
occasionally see the cursor change to a small crosshair. This
shows that you are over a snap point, like a corner, node,
the center of a line, or the center of a shape. If you click at
this moment, the point you drag the object from will be that
snap point. When dragging an object to move it, as you get
near other objects, those objects may also snap the cursor
location, allowing you to position shapes perfectly with each
other. If you are close to a grid point, the selection will snap
to the grid as well.
There’s a tool for that:
Then you can make them the same width, too!
