Anyone ever export snapmaker’s library for lightburn use? It is VERY accurate and a great place to start for the 40w and 2w lasers. Thought id post this to check. Right now im opening Luban for its settings and manually checking settings but surely there is a better way!
Can you export Snapmaker’s library in any format?
I found this page with some recommended parameters. Not sure, if there are more in Luban.
An AI might be able to convert a neatly structured spreadsheet into a LightBurn Material Library if you show it the structure of an example .CLB file for the reference.
I’ve tried this once for a Creality Falcon, and it worked quite well. Though I had to do some manual cleanup.
