I’m trying to get use to a new laser cutter and light burn. I tried 3mm thick MDF and the material test under “Laser Tools”…oh, and I imported the settings file from one of the other forums on here.
The laser moved around for a bit and finally started doing some lazing, and after a minute or so the machine beeped loudly and gave me the flash code for the burn or fire detection system and light burn could move the laser head but not power it up again until I power cycled the device. The result on the MDF looks out of focus, and like it hadn’t burned through:
I slid the focus lug on the Ray to the other extreme and got a similar looking result.
So I tried making a square at 100mm/sec and 20% power and it did one edge and the burn detector went off. I tried a circle at 6000mm/60% power and it got more or less one go around before the burn sensor went off and I had to power cycle again. I tried a hexagon at 300mm/35% and no dice there either.
It is harder to see what is up for this second set, but:
I don’t know if the machine is broken, or if I’m too heavy handed on the power or if I found a sheet of MDF that hates diode lasers (it is actually an off cut from my 20W CO2 laser, but that machine has a lot of other issues so I was hoping this snapmaker would work well for me,…)
Does anyone have any ideas on experiments I can try? Or if anyone has a similar machine what settings do you use for 3mm thick MDF?
Maybe MDF is a bad choice of material? Is there a better option for thin low cost burns? (I’m mostly making box inserts for boardgames and minis…although I was hoping with the advertised ability to cut up to 15mm thick wood on the Ray that I might cut exterior boxes as well for some projects)
