Snapping function does not work as discribed
Hello,
when drawing a line e.g. between two corners of two rectangles the cursor snaps to the desired corner of the first rectangle does does not snap to any corner (or line) of the second rectangle. Pressing the ALT/OPTION button while drawing the line does not help either.
All proposals neither from this forum nor from the web help. Any idea what I might do wrong?
If you´re dragging the line it doesn´t snap.
But if you pay attention to the changes in the cross and just click one corner then the other it just snap to the corners.
Remove .txt at the end to see the .mp4:
Recording 2026-10-18 162159.mp4.txt (1.0 MB)
Unfortunately there are no changes to the cross. :slightly_frowning_face:
The defalt Object Snap and Grid Snap distances may interact weirdly with your monitor and workspace zoom, because the former is in millimeters and the latter in pixels.
These settings work well (for me, anyhow) on a 27 inch 2560Ă—1440 monitor:
Might have something to do with the OS snatching keystrokes before LightBurn sees them, but ya never know.
I´m on Win11 and tested with RC-8 and 2.1.04.
Remember to not click drag, with the Drawing Lines Tool just click one corner then the other. Unless this is a Mac thing…
…here on my MacOS on MBP, everything works as it should, i.e. click on 1st corner, drag to the next corner and click again. To finish the process of drawing the line, I have to right click once.
Hi,
the last two answers helped me out. Usually I’m clicking and holding the button. In Lightburn it looks like you need to click once, drag the mouse and than click again. Now it wokrs also for me. :grinning_face:
Thanks.
If I drag it doesn´t work because there is no cursor changes and no snap.
I must click one corner then the other:
Recording 2026-10-18 191802.mp4.txt (1.3 MB)
It could look like you’re in curve mode
When dragging it defaults to smooth.
Example:
start the Draw Lines Tool and set to smooth
click one corner then the other still in smooth mode.
“distorted” the line for a while and right-click to exit the tool, The line becomes a straight line between the 2 corners.
Recording 2026-10-18 230356.mp4.txt (2.0 MB)
I assume you hold the mouse button down, you only have to click briefly once and drag the line to point B. If the line is activated, a small angle is visible, if you press S or if it is set to smooth, it changes to a small arc.
Check the recording, I this case doesn´t matter if it is in corner or smooth mode.
Basically we are saying the same, I assume (maybe wrong assumption) that dragging is holding mouse left-button pressed while moving the cross cursor as the OP (and maybe others):
Maybe call @JackieG (sorry) to rectify/clarify the docs;
For the Primary Shapes this is ok,
Sorry, but I don’t understand your problem and yes, I’ve watched your video.
moving shapes or working with lines are 2 completely different things, these are lines Joe (1st post) has trouble connecting and that’s what I keep referring to
No need to apologize for tagging me! It helps me improve the docs to make things better for everyone. :slightly_smiling_face:
I’ll take a look at this thread and see what I can do for clarifications. It may be a day or two before I can get to this one.
