I’ve got the same settings in mm/min:
Snap to object : off
Snap to grid : On
Visual Grid : 10
Grid snap distance : 10
Click-selection toleranche : 3 (tried with other doesn’t seem to change anything)
Object snap : 10
Trying to draw a line and make it snap to corners of the grid, like it does in the video, but wherever I click is wherever the point of the line is. No matter if I hold ctrl, or alt, doesn’t snap to the grid…
Hi, so, I’ve prepared for recording the issue, I relaunched lightburn, and it worked now…
I’ve tried troubleshooting it for at least two hours before posting, also restarting lightburn, I don’t know why it just works now. Tried to recreate the issue as I did draw some shapes before starting to snap to the grid and other stuff, but it just works now no matter what I do ^^ So I guess, there’s no problem anymore. Weird.
IIRC, when either of the two Edit → Settings → Snap to Grid / Object switches are off, then holding Ctrlenables their snapping behavior, but it’s been a while since I fiddled with those settings.
