Snijden mogelijk buiten bereik
Hallo,
Ik krijg dikwijls de vermelding “snijden is mogelijk buiten bereik” bij Lightburn. Wat betekent dit en hoe los ik het op? Dank.
Hello,
I often get the message “cutting may be out of range” on Lightburn. What does this mean and how do I fix it? Thanks.
Depends on what you are doing.
I expect all parts of your drawing are within the specified work area of your laser. You can use CTRL-A to select everything. Then use the preview window to see if you view what you expect.
If your drawing has parts outside the work space, maybe you can shrink it a bit.
Another thing, especially with images, is the Overscanning setting in the Cut Settings Editor window is too much. When Lightburn computes the travel distance, Overscan is included.
