How do I snip and delete the highlighted lines out of this example. These green lines are a border around a nameplate and the circle is intended to be drilled after lasering for a screw hole to attach the plate to some machinery.
I drew the border then put in a circle. I used the offset shapes tool to get wider lines via “Offset Fill” for the burn. I would like to eliminate the highlighted lines of the border in the attached snippet
I selected the outer two lines and Grouped them. I selected the Grouped perimeter lines and the Outer circle. The line form (the style of the dots) is different when a Group is selected. Note that the dashes are different on the outer circle than on the perimeter. I was shown this helpful detail not that long ago.
