mohon kami dikirimkan link yg sesuai lightbur Sculpfun S9 saya, masalah sumbu X tidak bekerja sedang sumbu Y arah terbalik pembelian alat di offical namun tidak diberi arahan akhirnya saya langsung ke penjual software. namun bila di forum ini ada yang dapat mengatas permasalahan saya mohon saya dibantu terima kasih all brother
Please send us the appropriate link for my Sculpfun S9 lightbur, the X axis problem is not working while the Y axis is in reverse direction. I bought the tool officially but was not given any instructions, so I went straight to the software seller. However, if there is anyone in this forum who can solve my problem, please help me, thank you all brothers.
New machine, right? You just recently assembled it, right?
- Make sure the Xaxis cable to the motor is properly plugged in on both ends.
- Make sure the Yaxis cable is properly inserted. It may be possible to insert one end backwards (turned 180 degrees).
The Sculpfun machines are normally connect and use without making any changes. There should have been an assembly manual in the box with the laser.
