I’ve made a software to adjust existing depthmap and also to generate depthmap from an image/photo.
- You can zoom in the adjusted depthmap by clicking on the picture and move your mouse. Click again to dezoom.
- You can now generate a depthmap from an image !
This depthmap is used to deep engrave on coin/slate or other material with a 3D effect.
You have to use the ‘3D slice’ mode in Lightburn.
Settings use for my 60W MOPA : 2500mm/s / 60khz / 200ns / 512passes / 95% / 900dpi (For brass)
/!\ This option works only if you have a NVidia GPU, the generation time depends on your GPU and size of the original file /!\
