Lightburn software has been working great until today. I have a xTool D1 Pro 20w laser and today it no working properly. The software does not recognize the speed or power cutting settings. If you have a 600.0 speed setting, the software uses 6000 instead and does not recognize the decimal. To get my machine to run at 600.0, I used 60.0. Also, the power setting is off. I cut material yesterday using a setting of 70% and my machine did the job using only one cut. Today, I have the same setting and it took six cuts to do the same job. I switched over to xTool software and my machine works as it should.
