Software Reset to New
Is there a way to reset the software back to bare bones new? I think I may have changed something & am not sure
I am running a Falcon 2 22W machine and the test files engrave & cut as they should. If i create a file in LB and save the Gcode to the SD card, all that happens is framing works, but will not engrave/cut
Any help would be appreciated.
Thanks
The easiest way to reset LightBurn to how it was when initially installed is to open LightBurn. Do a File/Open Prefs Folder. Then, Close LightBurn. Delete the files in the opened folder called prefs.ini. This will completely delete the LightBurn configuration. Restart LightBurn, and it will be as if you just installed it.
The other option, is to do a File/Load Prefs Backup. This will show you a bunch of old LightBurn configuration backups. You can select an older backup of your LightBurn configuration from before you made changes, and may help resolve the issue.
Thank you so much. That worked.
