I would like to make a word SOLID, not a line. No matter what font I choose, none of them are solid. Any ideas, suggestions? I made this in Word, but LightBurn creates only outlines.
LightBurn renders in wire outlines by default, but setting the layer to fill will generate fills when you preview or send to the machine. You can also set your system to show fills in the edit window, but we generally recommend you don’t use that for anything by spot checking.
Thank you!
Thank you! That helps.
