mazatty
(matt)
March 3, 2025, 8:13pm
1
Hello,
I was attempting to cut some rectangles with a single line.
But, all of the lines are not cutting. I never sent the file to the laser (Thunder Laser Bolt), but the preview window is not showing all the lines being cut.
I am getting the same result on my MacBook Pro running Sequoia 15.2 in Lightburn 1.7.06 and 2.0.0-RC-3 with optimization settings on and off.
Did I miss something? Does anyone else see this problem with my file? Has anyone else encountered this problem?
Thank you.
single line attempt not working.lbrn2 (5.8 KB)
thelmuth
(Tim Helmuth)
March 3, 2025, 8:39pm
2
You have a kerf ofset and in the advanced tab you have override PWM Frequency checked. Disable both of those and it works.
mazatty
(matt)
March 4, 2025, 6:14pm
3
Thank you very much Tim!
I was able to set the kerf offset to 0 and the file it previewing correctly now. I did not have to change the frequency to get it to work.
system
(system)
Closed
April 3, 2025, 6:22pm
5
