running lightburn version 1.3.01 .just started getting this warning box when i leave object outside the active work space. the job object is definetly inside the work surface grid. if i remove items i have stored outside the grid warning goes away?
Is “Cut Selected Graphics” in Laser window disabled? If so, enable this and you should be able to designate what objects to burn by selecting them before running a job.
