I downloaded and installed the update, and now I am not getting the origin square that shows where the file will start? If I choose “Cut Selected Graphics” and “Use Selection Origin” it shows like it should but without those there is no indication of an origin point.
Also, when I frame a job it’s going WAY outside the area I intend to cut/engrave?
Was there an option that got default-toggled with the new install?
I’ve got a client job to finish tonight and I can’t do it like this. Never should have downloaded the update until that was finished. Can I roll back?
However, are you sure that there’s nothing out of bounds in your file? Ctrl + Shift + A will frame the contents of the job (or the current selection) - check to make sure that only captures what you think it should.
Dammit, as SOON as I posted I figured it out. I had another rectangle in the drawing that was so much bigger than the work area that I didn’t see it. Working as intended, sorry.
