Is there another way to space and center letters within squares other than individually?see photo
You should be able to do all shapes on a per column and per row basis. So select all shapes in one column, then align H-center. Repeat for each column. Then select all shapes in one row, then align V-center. Repeat for all rows.
So you’d need to do this 10x11 times.
Thank you that helps
