Hi there. I want consistent spacing between the lines of text that I am doing. I will have four lines of text centered inside of a circle and don’t want the text right up against the lines above and below but instead want a little room between each line. Any tips, tricks, and instructions are welcome!
That’s what the Vspace value in the Text Toolbar does:
Setting both Align X and Align Y to Middle will automatically center the lines around the midpoint of the text block, so you can easily align the whole thing with the center of the circle.
Ok Thank you!!
