I’m using xtool D1 grbl on lightburn. Since the latest update I can no longer see the power and speed bar before running project.
Can you further elaborate? Where are you expecting to see this?
Are you referring to the power and speed adjustments that dynamically appear in the Move window once a job has started? If so, that would only show during a job.
The cuts/layer screen is not there on opening lightburn and starting a project. Because the cuts/layer screen is not there I cannot adjust speed/power. Hope I explained better and thank you.
In the window tab at the top. See if Cuts/layers has a checkmark next to it. If not click it.
I will do that as soon as I get home in a few minutes.
You were correct. It wasn’t on. Thank you so much for your help…I really appreciate it!
