Hi, I’ve just got a Laser and for some reason when I choose slower speed the laser still travels fast so it doesn’t cut. Even if I select a slower speed it keeps going fast. Any idea how to fix. I’m a new user of the software and machine. Thanks in advance
Please post a screenshot (not a cell phone pic) of your entire Lightburn screen with your project loaded and the Cuts/Layers Panel and Laser Panel visible. Also post a screenshot of the Settings Window (Gears icon) with the Units and Grids tab visible and post a screenshot of the Device Settings Window (Wrench and Screwdriver icon).
If Lightburn is set for inches and you expect mm, then it will move 1 inch, not 1 mm.
Most of these work in mm, but it sounds like you have one set for inches, like Lightburn. Ensure both machines are set for the same unit.
Thanks, I got the measurement aligned and it seems to be sorted. Thanks for the help
Was it the unit setting … I.E. inches/mm?
