Speed settings change when used on another computer
Using the latest version - a file created on one computer when used on another computer the speed settings increase X60. Versions were the same and settings in the software mm/min were the same. This pattern had a multi layer line with 4 instructions that was the only thing different than other patterns that have always worked correctly on both.
Are you able to provide screenshots of old vs new computer showing this? This would be an unusual case.
sorry I have corrected the file - but when the laser tried to do 360000 for speed it was scary
