Hi
I use Lightburn with my Sculpfun 9, I have started engraving an image on a stainless-steel surface and found I have set the speed way to slow. Is there any way I can speed this up whilst it’s working.
Also is there something that I set or can set if the engraving stops, I can pick it up from that point once reset. We have lots of power problems. I want to just know if there is something in the software to set to pick up from that point as well as putting in a UPS.
There is a speed and power override setting in the ‘Move’ window when the job is running.
Also you can resume your engraving by adjusting the slider in the preview window and hitting ‘start here’, as long as the workpiece hasn’t been moved of course
Yes, your right I am Sure, I did increase it but can’t see a difference to be honest. I actually need much faster, but max is 200%. Thank you for your Help.
There is a relationship between speed and power. If you increase the speed by 100% (doubled), you also need to increase the power by 100% (double) to get the same result (it’s power per area).
