Hi, what is the max speeds you can set for cutting, scoring and fill on a XTool S1.
I no there not the same as the speed setting on XTools XCS software.
But they ARE the same as for XCS. (At least, once you’ve converted units.) They’re speed in linear units (mm/sec or in/sec), and %power.
The maxes will depend a lot on the material. When you change materials, it’s a good idea to have done a material test to see what works with that material. I don’t mean when you change from 3mm to 2mm basswood, but when you change from basswood to MDF or from baltic birch to acrylic, etc.
