You need to adjust the steps / mm in the firmware.
Go to the console and type in $$. Check the value behind $100 and adjust it accordinly.
Formula would be:
New steps = old steps / 46 * 20
Type in $100 = New steps (the calculated value of course)
Example: You enter $$ and find the value behind $100 is 160,
New steps = 160 / 46 * 20 = 69.565
You enter $100=69.565 and press Enter.
LightBurn Oz, Yes I had rotary mode enabled and after switching this OFF the program
made the perfect code and worked perfect, thanks very much for that.
Question, when do I enable rotary, only if a radius is programmed?
