While working on my offset settings, I notice that I have a good bit of squiggle in my lines. The attached image is from a 1”x.5” rectangle done at 600.
My machine is a Thunder Laser Nova 35 80w. Any ideas what to do for straight lines?
Check belt tension, and all bolts on the axis are done up first
Is there a specific tension I’m checking for? How do you measure belt tension? Am I looking for loose bolts or should I be tightening them to a specific torque?
No specific tension, just needs to be taught, so when you press the belt down it only goes 1 or 2 cm. If your Y axis belt is loose is could cause this wobbly.
Bolts just need to be done up so nothing is moving that shouldn’t again no specific touque.
