”stable”license choice
Hello community, I have to renew my license, I am currently using 1.7, UV laser ts 2, which version should I take? Between the beta and the rc, what is the most profitable, I am sewing a version with the least bugs possible and usable directly, because I see a lot of bugs from one version to another! Thank you for your comments
If you are not having problems with your laser and LB right now and need to be able to maintain production, then there is no need to update (with the criteria you set). But if you would like to benefit from the development LB has undergone since version 1.7 and generally be “current” in the future, then take the latest version and test it. It is not certain that the errors you are thinking of apply to your machine version, and you can always roll back to the last working version, quickly and without problems.
I would bere in mind that 80-90% of BUGS you see are not actually bugs, Some people don’t know how to use the forum search too find the solution they need, or are just too lazy and expect others to solve their problem for them. Yes there are some bugs but I have found that ones that affect general usabilty are usually fixed in a day sometimes even hours of being reported.
I’m not a novice, but at the price of the license it should work
With your active license, you can download and install any prior version of LB you like. So if a newer version contains too many bugs, just go back one version.
