Stack trace importing SVG
I just tried to import an SVG with version 0.9.23 on Windows 10 and got this stack trace.
Hi, have you sent a copy to the address, developer@lightburnsoftware.com?
It’s your best bet for help on this one…
That says you were exporting, not importing - are you sure? (was the project empty?)
I had just exported the graphics as an SVG from one LBRN file and was trying to import the just exported SVG into a different LBRN file I had just opened.
You know you can just Copy / Paste for that (it works between instances of LightBurn).
That said, I don’t get why it’d crash, and especially thinking it was Exporting. That’s odd.
I did not know I could copy and past vectors from one instance of LB to another. Thanks, that is a very useful tip
Yup - It stores content on the system in what’s basically ā€œLightBurn project fileā€ format, as long as you have the ā€˜Use system clipboard’ box checked in the settings, which is on by default.
