So when I engrave or cut the laser moves to the same position it starts from. When I use the rotary and engrave tumblers the laser head goes to a differant position from where it starts. This has changed since I upgraded from 1.6 to 1.7.01. How do I change so laser head parks after engraving in the same position it starts?
I will check next time I am at my machine, but I know the laser head is moving to neither the starting or finishing position.
not sure if return to finish should be checked or not…
I have always used " Currant position"
You need to select “Return to Finish Position” if you intend to park the laser head in a certain location. That location is set below on “X” and “Y”
take a look here:
even with the red icon
I am not able to move into the green square, before I engrave or cut. If not inside the green square positioning is not accurate.
And yes, it does return to finish position when finished .
