Hello,
just had a power cut while running a job and it stopped engraving in the middle of a shape. Is there a way to tell LB to start it from the top, instead from the bottom (default)?
You can start a job from anywhere you like using the preview - drag the time slider to the spot where it died, then click ‘Start here’ at the bottom.
You can run an engraving from top to bottom by changing the ‘Scan Angle’ value in the Image or Fill settings from 0 to 180 degrees.
Thanks, will choose to go for option number 2 as this shape is a bit awkward and it’s hard to tell where it stopped exactly. Thanks Mr LightBurn!
