Is there a way to make the programs job origin the center of only the layers that are set to output rather than the center of all the layers? I have my zBed all drawn up in the program and my rotary drawn up in the program to assist in placing parts properly, however when i try to place artwork for using my rotary, i use the “start from current position” function, but the origin shows up in the center of the work space rather than the center of the artwork im outputting. Is there a way to change this other than deleting all of the other layers?
It does this intentionally because often you want to re-cut just a single item / layer after running a job, and don’t want the position to change.
To cut a subset of the job with it’s own origin, use these:
HECK YEAH! You are a life saver!
