Start point of a task
I have this task and I need all the pieces to start cutting from the right in the center regardless of where the starting point of each piece is.
Is there such an option?
You cannot override the start point, but you can move it using the Node Tool.
You can set a start point with the Set Start Point tool
I use the router professionally, it’s a big waste of time to have to put a start point in each design separately. The table is 77*110 cm 60-70 designs at a time.
Thank you very much for your time.
This is just the beginning - remember, MillMage isn’t yet for sale - significant toolpath optimization will come in the near future.
I like your little donkeys, I bet that’s a fun project
Just for my curiosity, what is the need for this? Can you explain why the starting point matters? Thank you.
I don’t need to build bridges.
You come here for help. When someone here asks for help, you give a cryptic answer. I am sure that is not what you meant to do, but we may not be familiar with your terminology.
I too was wondering why your process required a specific starting point. Can you give us more detail?
A process can require a specific starting point - or not. We don’t need to know the specifics if they are not offered.
When cutting from right to left, place the starting point on the right ( without bridges ), the piece will not be thrown out by the tool when cutting. The same applies vice versa.
Google translate
That makes sense. I am guessing the parts are different. Otherwise you could repeat the same part with the same starting point.
I cannot imagine me doing 60-70 pieces in one operation.
Thank you for the explanation
