Starting Position Galvo
Hi @ all
is there any chance to change the starting position on a Galvo machine? My Galvo works well, but when i change between Galvo and DSP (50W OMTECH) everything is flipped. Galvo says startpoition Front Left. CO2 back left. Thank You!
I would look at optimization. May get you what you want. Seems like mine starts at the bottom right corner if I “Choose corners, if possible” and “From Right”. If I try it on something without a corner, it starts on the closest edge to the right. Don’t see how to combine both.
This is working as designed. What you need to do, is flip to the different device before you open a file. LightBurn will orient the file properly to whatever origin the machine has, but when flipping between different origin machines with a file open, it will flip the design around.
