Starting project laser fan comes on and immediately program stops
Command console displays this message.
Can operate the gantry from the control console, device homes properly on start-up. Laser does not respond to the “Fire” button. Device will frame the loaded project as expected but the above occurs when attempt to start project.
Try unplugging the black cable to the Laser head
I would assumin you have a power adapter that failed or is failing
WIthout laser head, will motions of your project finish?
Also confirm your power adapter is 24v 4am or higher
