This issue just started happening, I’m getting spots in the solid black areas and when I went to do a material test it’s not printing everything. I have touched any settings so I’m wondering if my laser is getting weaker. I’m using a 10watt diode laser, if you can point me in the right direction that would be great thanks
If I got these results, I would think it is a material issue rather than a mechanical problem.
Have you tried the Material Test on something else, like wood?
Yes and it’s working ok on wood, I’ve never had an issue before and it’s been almost 3 years with it and I didn’t change any settings that’s why I’m confused
Well, that answers the question of whether or not it is the laser. ![]()
Looks like a wire failing but could be something else .
