Starts with burning a line from origin to starting vectors
can anyone tell me why or the setting to turn off for this to not burn a line from origin to the first vector?
There’s not a setting for that - that’s just wrong. How did you get the file to the controller? USB cable or USB drive?
thumb drive. here is the exact file
DemonPlate_r1.zip.txt (19.2 KB)
I reexported the file adding a small low power circle in the corner and it didn’t do that.
Now what if you remove the added small circle and export again, do you have the same problem result?
no. so it was either a glitch when the file saved from the thumb drive to the controller’s memory, or a glitch in lightburn the first time. no clue.
Ok, if you run into the issue again please let us know.
