When I start a job and for example i see it may need a slight adjustment i would have to stop and try my best to realign.
I would like to suggest that when you hit the stop button it automatically goes to the start position.
‘Stop’ is considered an emergency abort. If your hand was pinned by the laser or you were about to drive into a clamp and you hit stop, you wouldn’t want additional movement at that point.
If you use ‘User Origin’ mode, you can click ‘Go to Origin’ to return the head to the previously set user origin, though both ‘Absolute Coords’ and ‘User Origin’ mode will automatically send the laser to the correct starting position regardless of where it is when you start the job.
