Stopped framing after upgrade, still cutting
laser stopped framing after the upgrade. Cuts fine, and you can hear the mirrors going when you hit the frame button. Can someone send me the picture of the initial settings used to get it to work? thanks
Greg
That thing happened to me as well… are you using a fiber galvo? I am unable to make it frame again no matter how hard i try…
Check that your red-light port is set properly. What is it set to right now?
Unless someone else has the exact same model of laser and board as you, this information would be meaningless, and you haven’t said what you have.
