Stopping and restarting from same point after adjustment
So I started a job and the first two layers (engravings) came out great. I had to step away for about an hour and when I came back it was on the cut layer. However, I accidentally set the cut layer to cut the groups “individually” and not as groups “together”. The time is 10x longer than what I had done before because of this. Is there a way to stop it, adjust the cut and restart it from the same point with the new parameters without having to recenter and reframe it again “hoping” I am in the same spot?
I have been able to stop a project, adjust settings that have not been performed. Then, i go into Preview and scroll to the point you need to restart from and select START HERE along the bottom of the preview screen. Hope this helps
