I have used 2 machine profile before with my diode laser. 1 for normal work and one for using the rotary - works fine.
Now I have a CO2 laser with a Ruida controller and added a new profile.
First thing I noticed: If I activate the rotary in the dialog and close the dialog. The rotary button in the toolbar is not green and I see no green notice and in the status bar, that the rotary is active.
But the rotary works fine (after power cycle the laser) .
Now I tried to add another profile (one for normal and one for rotary) like I before with my diode laser. But this is not working. The rotary active state is not handled correcty. I can not switch between profile to activate and deactivate the rotary.
The rotary state stays the some while changing Ruida profiles. Like I said, works fine the my diode gbrl profiles.
( I am using the lastest preview version of Lightburn)
I understand that the controller need some configuration for the y axis - remove limits etc.
But where is the problem, to store the active / not active state in the profile and after changing the profile, just send the the right config data for the controller, depending on the active/not active state.
Then you just have to reset the ruida controller at the machine after chaging the profile and everything is fine.
