Can any kind forumist help me with a strange problem.
When I have completed the image in LB and cut it out, it does not look like the one on the screen. It gets displaced (staggered) Compressed.
the first photo is printed out on a papper from the screen
The second one is cut out on plywood
Hope I made a right words for it.
What did I made wrong ? Is it somthing in the settings ?
Either your firmware settings are not correct (steps/mm setting for the y-axis) or your y-axis has a mechanical issue that it doesn’t move as expected.
where do I check the firmware settings
Make sure you don’t have “Enable Rotary” button turned on in the laser control window.
The first thing to check is whether Enable Rotary has been inadvertently activated:
If you’ve turned on Show Rotary Enable on Main Window, the switch is directly below the Frame button, where it’s absurdly easy to hit by accident:
Thx Jim
That solved the problem
I had not unlocked the rotary.
Now I´m back in business. ![]()
