I am struggling to cut through 3.2 mm hardboard. Any suggestions
Hi I am not using air assist. Busy cutting out desktop pencil cases. I am going to attach a image of the settings. The engraving looks good just the cutting is a problem.
Thank you so much for your time.
Regards
Can I leave it on 23 passes. Yes I am in well ventilated area with fans.
The wood is 3.2mm thick can I leave the cut on 4 and how does skip work
Got my first laser about a month ago. Wanna start my own business in Arts and Crafts. I am going to try it like you said and will let you know what happens. Thank you so much for your help.
Yes that makes sense, if I pause the current job and modify it will the machine pick it up
Is it better to have air assist on the machine. I do have a small desktop fan running on the job in progress.
Ok thank you so much, will let you know how it went and if I have more questions. Thanks again
MDF is hard for most diode lasers, you should get medite.
A fan is not sufficient enough to be called “air assist”, you need to get an air assist kit for your Otur. They sell them on their website.
I take that back, they sell them on Etsy and you need to buy the pump.
