Struggling to get lightburn to connect atomstack m4
I’m running 1.701 with the galvo compatibility Windows 10 pro The laser is enjoywood m4 (which is a clone of the atomstack m4) I’ve installed the ezcad2 driver with the lightburn installer although for it to show up i switched it to winusb, using zadig driver utility.
It’s showing up under the USB devices section in device manager. It just doesn’t show up when i click “find my laser” i have tried creating my own preset using the bslfiber option but to no avail.
I can disable the current driver so its then detected under a com port on the pc but that doesn’t help me get it connected in lightburn.
I have also tried multiple versions of lightburn 1.7.00, 1.7,02 etc and still no luck.
Hi Tom
Could you show us how the M4 is detected in Device manager.
I was certain the M4 was a BSL and not a EZCad driven laser.
If i am right, you need the native drivers, not replace them with Zadig
i have uninstalled that drivers, its now displayed under the ‘universal serial devices’ tab and is called ‘sea-laser’ i clicked to see what driver it has and its called ‘libwdi’
Usually they are called “Cypress”, but that should work.
You could now try to add manually > BSL
On your software package from the manufacturer do you have a BSL.cfg file you can use on the importer?
I’ve tried that and it still displays ‘disconnected’ no movement from the laser either even after creating that profile with the cfg file
I have just checked, and its now showing up under (com15) but as i understand bsl lasers dont use com ports? so maybe i need a different driver other than ‘libwdi’
