Subject: Looking for official iKier K1 Pro Max 70W Material Library (.clb file) for LightBurn Pro (version 2.1.04)
Hi everyone,
I am a new user of the iKier K1 Pro Max 70W diode laser, and I am currently setting it up with LightBurn Pro (version 2.1.04) on an ASUS Gaming laptop (17-inch) running Windows 11. My machine is running the firmware version: Jan 13 2024-v1-507-v1-507.
While I am completely new to diode lasers and LightBurn, I have a solid background and years of experience operating CO2 laser machines using Ruida controllers.
I am trying to import the official iKier material settings into LightBurn. I downloaded the parameter file directly from the official iKier website, but unfortunately, it is not in a format that LightBurn can recognize (it is not a .clb file) and I cannot load it into my Material Library.
Could anyone please share the official or a verified iKier K1 Pro Max 70W .clb file compatible with my setup? Alternatively, if there is a clean way to convert iKier’s official data into a LightBurn library, I would greatly appreciate your guidance.
Thank you so much for your help!
Best regards,
SAM331
You’ve probably already discovered this yourself.
https://de.ikier.com/cdn/shop/files/Parameter_Table_of_K70_MAX_Laser_Module_for_LightBurn_Software_1.pdf?v=3449290391262912308
In fact, my experience with my IKIER laser is that the specifications are far too optimistic. In any case, I had to run several tests with the material I was using.
