The backup files created by Lightburn serve no purpose for me. As you know, they are deleted when I close Lightburn and also when I save a file. If I have made a mistake, there is simply no backup file left. The whole backup system in LB is therefore obsolete and only useful if LB crashes. LB has never crashed for me. It is simply very good software.
My CAM (CamBam) has a more sensible backup solution. I can set a number of backups in the configuration. The backup files are created when saving or automatically after an interval. They are given a name, file extension and a number. If 3 backups are selected, the file names are xxxx.cb1, xxxx.cb2, xxxx.cb3. The fourth backup then overwrites the first file.
These files remain even after the file or program has been closed.
This means that the files are also included in the hourly interval of the general data backup by timemachine. After deleting the number in the file extension, the files can be opened normally.
I would like to have such a backup system for Lightburn as well.
Thank you
ralfg
